[OpenLayers-Users] WMS in OpenLayers: Objects get Cut
Pfirter Lukas lp at rpag.ch
Fri Jul 20 07:37:51 EDT 2007
Hi Chris, and thanks for the help.
I downloaded the latest svn version (I think it worked, I don't have SVN, did it with "wget -r").
http://map.webser125.lookass.ch/openlayers_svn/ex_rpag_google_untiled.php
Copied the file that includes OL in there and still the same thing happens.
As you see, this does only happens with OpenLayers.Layer.WMS.Untiled. Without "Untiled", it works:
http://map.webser125.lookass.ch/openlayers_svn/ex_rpag_google.php
But I have other problems with that one: My mapserver doesn't continue object descriptions in tiles that end in other tiles. I know this can be fixed with "tilecache" or tools like that, but this one seems to be a bit too complex for that I just want a simple WMS displayed in OL the right way.
Do you want me to add these new links to the Bug report too? I will for sure keep them online until it is fixed (I saw milestone is 2.5, gonna take a while though?).
Thanks,
Lucas
-----Ursprüngliche Nachricht-----
Von: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Gesendet: Donnerstag, 19. Juli 2007 15:07
An: Pfirter Lukas
Cc: Users at openlayers.org
Betreff: Re: [OpenLayers-Users] WMS in OpenLayers: Objects get Cut
On Wed, Jul 18, 2007 at 11:05:35AM +0200, Pfirter Lukas wrote:
> Hi Benoit, thanks for your quick answer!
> Unfortunately, putting the WMS layer above the Google-Layers in the code (http://map.webser125.lookass.ch/openlayers/ex_rpag_google_test.php) doesn't change anything, WMS still hides partially.
> I've seen that I just have to move the map a slightly little bit after changing the zoom to make everything visible like should be... Isn't there like a function that will move the map 1 px everytime you change zoom? Or another workaround for this? Is it a bug actually?
There is definitely a bug here. The problem is that the bounding box requested for the tile is not actually in the right place -- it's off by about .02 degrees, it looks like, which is a fair distance.
Could you try upgrading to the latest svn code --
  svn co http://svn.openlayers.org/trunk/openlayers/
will get the code for you -- and see if it still happens? It looks like you're currently running against 2.4-RC2, and although I'm not really hopeful that this change will fix the problem, I'm hopeful that it will at least elmiinate that as part of it.
Another question -- did you see this with tiled layers as well? I think the answer is yes, but I can't remember.
Thanks in advance for trying to help us dig into it.
Regards,
Christopher Schmidt
MetaCarta
