[OpenLayers-Users] WFS Layers blocks excution?
Jackey Cheung cheung.jackey at gmail.com
Wed Jun 6 21:16:57 EDT 2007
Yes, this should be a solution for the problem, but even this solution has
its limit. Think about something like the Wikimapia, even we don't use XML,
when there are lots of "WFS" objects to be shown, I wondering how lagy will
it be.
Too bad I'm busy on my work and have no time to look into it, just wanna
talk about the feasibility of implementing WFS features with timed process
(window.setTimer() or window.setInterval()). Say, with a timer process,
which process and display limited number (say, 2~3) of features at a time.
By doing so, WFS layers will be loaded slower, in exchange of less
performance impact to the whole user environment.
Agree?
----- Original Message -----
From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
To: "Jackey Cheung" <cheung.jackey at gmail.com>
Cc: "Christopher Schmidt" <crschmidt at metacarta.com>; <users at openlayers.org>
Sent: Thursday, June 07, 2007 03:14
Subject: Re: [OpenLayers-Users] WFS Layers blocks excution?
> Isn't Tim or someone else working on GeoJSON to give an alternative to WFS
> that does not have the XML parsing and overhead? I would think that this
> might be a good alternative. If this is really happening, then we might
> want to ping the mapserver list about support GeoJSON in the 5.0 release.
> -Steve W
> Jackey Cheung wrote:
>> I've been using Firebug for some time, and do tracked OL with FB. The
>> most time consumer is XML process on the FireFox. And I've done the same
>> thing in IE with Visual Studio, and found out XML process consumes most
>> process time too. Currently, I've made some change to the WFS layer, to
>> utilize non-XML methods, for more performance. Well, deviated from "WFS"
>> actually.
>> Just curious, how others do it? I haven't got time to study other similar
>> maps on the map, but they seem to be better in performance. I've though a
>> little about using timed process to deal with timely process, such as
>> WFS, so the browser won't hang up while busy on processing XML data.
>> From: "Christopher Schmidt" <crschmidt at metacarta.com>
>> Cc: <users at openlayers.org>
>> Sent: Wednesday, June 06, 2007 09:51
>>> On Wed, Jun 06, 2007 at 09:13:49AM +0800, Jackey Cheung wrote:
>>>> I've updated to 2.4, it do improve quite a lot, but I'm still suffering
>>>> noticeable (little, but still noticeable) lag while panning, and it
>>>> takes
>>>> around 1 second to load the layer when refresh. Is this normal?
>>> I would say you're probably dealing with pretty standard behavior at
>>> this point, yes.  If you get Firebug (debugging extension for Firefox)
>>> you can watch the time that requesting data from the server actually
>>> takes: this may help you determine whether your 1 second refresh time is
>>> server or clientside.
>>>> You've mentioned about pathological dataset. I'm using MapServer as the
>>>> WFS
>>>> server, returns 3 data fields (ID, Name, coord) in GML. Isn't it
>>>> general?
>>>> If you were referring to the server side process, I just wondering,
>>>> does
>>>> server side process affect the execution flow of the client side?
>>> The server side execution doesn't affect the client.
>>>> What should I focus on to tune this WFS thing in OpenLayers?
>>> First, get firebug and time the requests.
>>> Second, turn on profiling and check out the time to do things in
>>> Firefox. (You can't do this in IE, but the performance is going to be
>>> mostly the same -- issues generally show up in both.) If you're seeing
>>> major differences between IE and Firefox, my best advice is basically
>>> "Good luck". I don't have any experience or advice in debuggin speed
>>> issues in IE.
>>> Regards,
>>> Christopher Schmidt
>>> MetaCarta
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
