[OpenLayers-Users] Unable to use both OpenLayers.Layer.Google and OpenLayers.Layer.TMS
bdw bdwilton at gmail.com
Thu Jun 7 00:01:45 EDT 2007
Hi Tim,
Thanks for your reply.
I performed the following tests :-
1) Set OL to default EPSG (i.e. 4326), one non-cache wms base layer - worked
2) Set base layer to tilecache wms - worked
3) Set EPSG 54004 with one non-cache wms base layer - worked
4) Set base layer to tilecache wms - nothing displayed
Then I tried a single call to the tilecache like you suggested, the
following call :-
http://192.168.0.4:8081/?LAYERS=nzmap&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A%2054004&BBOX=16280475.8648%2C-1300840.7104%2C17532820.136%2C-48496.4392&WIDTH=256&HEIGHT=256
returned :-
An error occurred: couldn't calculate tile index for layer nzmap from
([16280475.864800001, -1300840.7104, 17532820.136, -48496.439200000001])
  File "/var/www/cgi-bin/tilecache-1.8.1/TileCache/Service.py", line 452, in
wsgiHandler
  File "/var/www/cgi-bin/tilecache-1.8.1/TileCache/Service.py", line 395, in
dispatchRequest
  File "/var/www/cgi-bin/tilecache-1.8.1/TileCache/Service.py", line 120, in
parse
  File "/var/www/cgi-bin/tilecache-1.8.1/TileCache/Service.py", line 129, in
getMap
I assume this index error means that the tolerance value like you mention is
at fault, I dont
have a good enough understanding of the internals as to why the EPSG:4326
works and
EPSG:54004 causes this tolerance error.
Was thinking it could be my geoserver setup as I added the 54004 SRS entry
but from watching the
logs the requests never get that far and stop as you suggest (I believe) at
the tilecache.
View this message in context: http://www.nabble.com/Unable-to-use-both-OpenLayers.Layer.Google-and-OpenLayers.Layer.TMS-tf3865655.html#a11001507
