[OpenLayers-Users] Bug with switch layers in Opera and Konqueror?
zenzero-2001 John.Westwood at port.ac.uk
Tue Jun 12 16:25:49 EDT 2007
Ok, The Internet Explorer problem is a non-issue since it works fine in
Windows.
I have tested in Safari and have found that the problem with switching
between base layers also occurs with this browser. I assume this problem is
something to do with browser (in)compatibility and Ajax? If so, I guess the
problem could lie within the Rico framework? Does anybody have any possible
ideas for a work around? To summarize, I have tried the following browsers:
Firefox - PASS
Internet Explorer - PASS
Opera - FAIL
Safari - FAIL
Konqueror - FAIL (not so bothered about Konqueror)
I guess the problem is symptomatic of the lack of standards between
browsers. Am I right or am I doing something dumb?
Regards,
John W.
zenzero-2001 wrote:
> Hi,
> I have a problem with switching between base layers in Opera and
> Konqueror. The problem can be reproduced both on my application and on
> the Mumbai freemap, mumbai.freemap.in . To reproduce the problem follow
> these steps:
> Let a base layer completely load in.
> Switch to a second base layer and let that completely load in.
> Switch back to the first base layer - it does not appear.
> This will happen when switching to any base layer that has been
> previously loaded, without zooming or panning between layer switches.
> Any ideas on what the problem could be? May be something to do with
> their AJAX implementation?
> I have a slightly different problem with ie6 on Linux (but only with my
> application); the tiles of the layer are not rendered as they are
> calculated but only after all the tiles in that view have finished being
> calculated. I think that this is a separate issue to the layer switching
> problem.
> Regards,
> John W.
> P.S. I like OpenLayers a lot, I hope that it will continue to develop.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Bug-with-switch-layers-in-Opera-and-Konqueror--tf3878861.html#a11086260
