[OpenLayers-Users] Problem showing OpenLayer controls in a page with a DOCTYPE
Christian López Espínola penyaskito at gmail.com
Thu Jun 28 07:32:38 EDT 2007
Hola Ruben,
The doctype mustn't be a problem with OpenLayers. I'm using ASP.NET
with OpenLayers and I hadn't any problem.
Please check the HTML source generated by your application and if you
can't find the solution, post a piece.
Hope this helps
On 6/28/07, Ruben Pardo <correosig at gmail.com> wrote:
> Hi everybody,
> I've got a problem  showing controls with OpenLayers when i put a doctype on
> my html page.
> I'm integrating OpenLayers in a custom jsf component, that autogenerate the
> DOCTYPE.
> It shows me the layers, but not the controls over the layers (PanZoomBar,
> Overview, etc...)
> It works fine when i remove the doctype in the generated code.
> ¿how can i solve this?
> Thanks a lot in advance
> My generated code is ...
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
> "http://www.w3.org/TR/html4/loose.dtd" >-->
> <html >
>     <head>
>         <meta content="text/html;charset=ISO-8859-1"
> http-equiv="Content-Type">
> </head><body onload="init();">
>      <style type="text/css">
>         #map {
>             width: 800px;
>             height: 500px;
>             border: 1px solid black;
>            </style><script src="js/lib/OpenLayers.js"
> type="text/javascript"></script> <script
> type="text/javascript" >
>                var map,layer;
>          function init(){
>            map = new OpenLayers.Map('map', { controls: [],tileSize: new
> OpenLayers.Size(500,500) });
>           layer = new OpenLayers.Layer.MapServer( "OpenLayers
> WMS","http://192.168.212.20:84/cgi-bin/mapserv.exe?map=/ms4w/apps/prbmosaico/htdocs/prbmosaico.map
> ",{layers: 'PARCELASDE', TRANSPARENT: 'true'},{ maxExtent: new
> OpenLayers.Bounds(186555.49,4136068.22,211516.81,4156763.12), maxResolution:
> 104} );
>            map.addControl(new OpenLayers.Control.PanZoomBar());
>            map.addControl(new OpenLayers.Control.MouseToolbar());
>            map.addControl(new OpenLayers.Control.OverviewMap());
>            map.addLayer(layer);
>                     if (!map.getCenter())
>                        map.zoomToMaxExtent();
>         </script>
>       <div  id="map"></div>
>        </body>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Regards,
