[OpenLayers-Users] Problem showing OpenLayer controls in a page with a DOCTYPE
Ruben Pardo correosig at gmail.com
Thu Jun 28 08:04:21 EDT 2007
I'm checking my html source generated but it doesn't work. I'm using
OpenLayers 2.4 API, and still have the same problem. When i remove the tag
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "
http://www.w3.org/TR/html4/loose.dtd" > it works fine.
My code  :...........
<html >
    <head>
        <meta content="text/html;charset=ISO-8859-1"
http-equiv="Content-Type">
    </head>
    <body onload="init();"  >
     <style type="text/css">
        #map {
            width: 800px;
            height: 500px;
            border: 1px solid black;
           </style><script src="js/lib/OpenLayers.js"
type="text/javascript"></script> <script type="text/javascript" >
               var map,layer;
         function init(){
           map = new OpenLayers.Map('map', { controls: [],tileSize: new
OpenLayers.Size(500,500) });
          layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS","
http://192.168.212.20:84/cgi-bin/mapserv.exe?map=/ms4w/apps/prbmosaico/htdocs/prbmosaico.map",{layers:
'PARCELASDE', TRANSPARENT: 'true'},{ maxExtent: new OpenLayers.Bounds(
186555.49,4136068.22,211516.81,4156763.12), maxResolution: 104} );
           map.addControl(new OpenLayers.Control.PanZoomBar());
           map.addControl(new OpenLayers.Control.MouseToolbar());
           map.addControl(new OpenLayers.Control.OverviewMap());
           map.addLayer(layer);
                    if (!map.getCenter())
                       map.zoomToMaxExtent();
        </script>
      <div style="margin:0px" id="map"></div>
</body>
2007/6/28, Christian López Espínola <penyaskito at gmail.com>:
> Hola Ruben,
> The doctype mustn't be a problem with OpenLayers. I'm using ASP.NET
> with OpenLayers and I hadn't any problem.
> Please check the HTML source generated by your application and if you
> can't find the solution, post a piece.
> Hope this helps
> On 6/28/07, Ruben Pardo <correosig at gmail.com> wrote:
> > Hi everybody,
> > I've got a problem  showing controls with OpenLayers when i put a
> doctype on
> > my html page.
> > I'm integrating OpenLayers in a custom jsf component, that autogenerate
> the
> > DOCTYPE.
> > It shows me the layers, but not the controls over the layers
> (PanZoomBar,
> > Overview, etc...)
> > It works fine when i remove the doctype in the generated code.
> > ¿how can i solve this?
> > Thanks a lot in advance
> > My generated code is ...
> > "http://www.w3.org/TR/html4/loose.dtd" >-->
> > <html >
> >     <head>
> > </head><body onload="init();">
> >         #map {
> >             width: 800px;
> >             height: 500px;
> >                var map,layer;
> >          function init(){
> > WMS","
> > ",{layers: 'PARCELASDE', TRANSPARENT: 'true'},{ maxExtent: new
> > OpenLayers.Bounds(186555.49,4136068.22,211516.81,4156763.12),
> maxResolution:
> > 104} );
> >         </script>
> >       <div  id="map"></div>
> >        </body>
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Regards,
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070628/fadfd23b/attachment.html
