[OpenLayers-Users] Does this map work under Mac/Firefox?
Christopher Schmidt crschmidt at metacarta.com
Tue May 22 12:55:24 EDT 2007
On Tue, May 22, 2007 at 10:41:00AM -0600, Gregor Mosheh wrote:
> A co-worker says that the map doesn't work at all under Firefox on a
> Mac. He says that he gets a message to the effect that a script is
> unresponsive or being slow. (which I know from Flash but not JS) I can't
> verify this behavior myself, as my lab is all Windows PCs.
> Are any of you using Mac/Firefox, and able to hit up my map to verify
> whether it works?    http://69.59.158.10/openlayers/
> If not, are there known problems with Mac/Firefox or workarounds I
> should try?
Firefox on Mac tends to be about three  to five times slower on complex
Javascript tasks than Firefox on Windows. That said, I have no problem
loading http://69.59.158.10/openlayers/ on my mac, and the code is
far simpler than many of the more complex Javascript tasks I've
performed on OpenLayers, none of which lead to problems with the
'unresponsive script' warning. I'd say that your coworker may want to
look into his plugins, etc. to see what else might be causing his
problem.
Regards,
Christopher Schmidt
MetaCarta
