[OpenLayers-Users] spherical-mercator
Eric Lemoine eric.c2c at gmail.com
Tue Oct 2 15:59:25 EDT 2007
On 10/2/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Oct 02, 2007 at 12:33:08PM -0600, Linda Rawson wrote:
> > But my base map isn't that projection.  I changed it to EPSG:26919.  Why
> > aren't my layers using that projection?
> I must be blind. I thought your base map was Yahoo with
> SphericalMercator. Yahoo with SphericalMercator is EPSG:900913. When I
> said "You can't change that", I meant that. The images are what they
> are -- and you can't reproject them.
> I'm probably confused. Can you explain why I'm lost?
IIUC Linda wants the WMS layer to be reprojected to EPSG:26919 on the
server side.
Linda, why would you want that? Doing that would lead to two layers
with two different projections, which does not seem right.
Eric
