[OpenLayers-Users] spherical-mercator
Linda Rawson linda.rawson at gmail.com
Tue Oct 2 16:13:56 EDT 2007
In this case my WMS layer is the following:
            var wms = new OpenLayers.Layer.WMS(
                "Canada Map",
                "http://wms.cits.rncan.gc.ca/cgi-bin/cubeserv.cgi?",
                {'layers': layerOptions, 'format':'png'},
                    'reproject': false, 'opacity': 0.4,
                    'isBaseLayer': false,'wrapDateLine': true
I was just trying to use your example.  In order for me to display the
layers in a certain projection from this service I have to tell it.  It
wants EPSG:26919.  It does not understand EPSG:900913 and fails on the
request.
Basically here is my goal....I need to use a spherical-mercator projection
to get the UTM coordinates to pass to this WMS layer.  The map can be in
whatever it wants I just need the SRS parameter changed for the WMS layer.
Linda Rawson
On 10/2/07, Eric Lemoine <eric.c2c at gmail.com> wrote:
> On 10/2/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > On Tue, Oct 02, 2007 at 12:33:08PM -0600, Linda Rawson wrote:
> > > But my base map isn't that projection.  I changed it to
> EPSG:26919.  Why
> > > aren't my layers using that projection?
> > I must be blind. I thought your base map was Yahoo with
> > SphericalMercator. Yahoo with SphericalMercator is EPSG:900913. When I
> > said "You can't change that", I meant that. The images are what they
> > are -- and you can't reproject them.
> > I'm probably confused. Can you explain why I'm lost?
> IIUC Linda wants the WMS layer to be reprojected to EPSG:26919 on the
> server side.
> Linda, why would you want that? Doing that would lead to two layers
> with two different projections, which does not seem right.
> Eric
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071002/9a2b241f/attachment.html
