[OpenLayers-Users] MapServer to OpenLayers line rendition
Christopher Schmidt
crschmidt at metacarta.com
Fri Oct 5 19:16:28 EDT 2007
On Fri, Oct 05, 2007 at 05:49:26PM -0500, Steve Lime wrote:
> Aileen: I'm assuming you're bumping your head against the URL configuration changes
> that were made in 5.0. Virtually anything you could do in 4.10 is doable in 5.0 but the
> mechanism may have changed. Can you pass along the URLs that are actually being
> sent to MapServer?
You can find this by following the 'pink tiles' troubleshooting tip on:
http://trac.openlayers.org/wiki/TroubleshootingTips
> If so, then I can tell you what changes would be necessary to
> make them work. Whether that means the OpenLayers interface will have to be updated
> I'm not sure of.
If Steve can figure out what URL you should be using, I can help make
sure that OpenLayers will use it.
Regards,
Christopher Schmidt
MetaCarta
