[OpenLayers-Users] Line Render 'bug' on drag
Andre Lockhart andre at covaluate.com
Wed Oct 10 02:44:54 EDT 2007
It does look somewhat similar, but this is a problem with dragging the map
after the line has already been drawn/rendered.
-----Original Message-----
From: Pierre GIRAUD [mailto:bluecarto at gmail.com]
Sent: Tuesday, October 09, 2007 11:26 PM
To: andre at covaluate.com
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Line Render 'bug' on drag
If I understand your explanation, there is ticket open for your
problem : http://trac.openlayers.org/ticket/965
No trick or workaround at the moment.
Regards
On 10/10/07, Andre Lockhart <andre at covaluate.com> wrote:
> I am working on an application where I am drawing lines over a map using
the
> OL graphics  API.
> After dragging the map and seeing the OpenLayers lines move with the drag
> event, I have noticed that when I lift my finger off the left mouse button
> the line re-renders at its former location for an instant then disappears.
I
> was wondering if there was a trick to suppressing this. The goal would be
to
> have a smooth movement of the map and drawing layer and not see flicker
and
> skew of the drawn features.
> Any help appreciated.
> Thanks!
> Andre
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
