[OpenLayers-Users] Line Render 'bug' on drag
William Bronsema
wbronsema.lists at gmail.com
Wed Oct 10 08:57:57 EDT 2007
Hi Andre,
I have a similar issue and have found that it only occurs in IE. Is this
the same for you?
Cheers,
Bill
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of Andre Lockhart
Sent: Wednesday, October 10, 2007 2:45 AM
To: 'Pierre GIRAUD'
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Line Render 'bug' on drag
It does look somewhat similar, but this is a problem with dragging the map
after the line has already been drawn/rendered.
From: Pierre GIRAUD [mailto:bluecarto at gmail.com]
Sent: Tuesday, October 09, 2007 11:26 PM
To: andre at covaluate.com
If I understand your explanation, there is ticket open for your
problem : http://trac.openlayers.org/ticket/965
No trick or workaround at the moment.
Regards
