[OpenLayers-Users] icons in Layer.Text
Linda Rawson linda.rawson at gmail.com
Wed Oct 10 11:09:31 EDT 2007
Tara,
For SQL Server,
Take a look at this article...
http://www.sqlteam.com/forums/topic.asp?TOPIC_ID=74882
 OR
You can set up an ODBC link and connect to that link via Excel to produce a
spreadsheet from which you could produce a text file.
Linda Rawson
On 10/9/07, Tara Athan <tara_athan at alt2is.com> wrote:
> I did finally run across the documentation on the textfile format here:
> http://trac.openlayers.org/wiki/MapViewerService
> Thanks for your help- I have it working now.
> Also thanks for the tip about working in Excel (or OpenOffice ;-) )- it
> is actually possible to create the text file in notepad but you have to
> put the tabs in the right place and then they look the same as spaces,
> so it is very inconvenient.
> Working in a spreadsheet allows me to fill down for all the duplicate
> icons, sizes, etc. instead of typing them out.
> Now if I can just figure out how to get the textfile from a database
> query... anyone have an example of that?
> Tara
> Robert J Becraft wrote:
> > See my example at http://www.metaphaze.com/Avalon/AMII_world_map.htm
> > You will need to use Excell to create the txt file.  Type each column
> > in the spreadsheet, then export as a .txt file.  It puts tabs between
> > the columns, and makes it readable to OpenLayers.  Using notepad won't
> > work.  The column headers are keywords that specify what type of data
> > is in that column.  I don't have the link to the help page I found
> > this on, it is on the OpenLayer's site though.
> > I positioned the icon's over the first letter of the layer with the
> > country names on it.  You can see this when zooming in.  I did this by
> > hand with the spreadsheet open and adjusted the LAT/LON values,
> > exporting and reloading the web-page until they were close.
> > The icon's themselves are 25x25 pels, I don't adjust the size.  It
> > seemed simpler to have them the actual size I wanted them to appear on
> > the map.  They are transparent gifs.
> > Eventually the text detail will come in from a dynamic piece of code I
> > haven't finished writing.  One idea I'm toying with is to build a menu
> > in the popup that zooms to a variety of features for each of the
> > countries.  The final product will depend on my time and how well it
> > works when I get to it.
> > Erik Uzureau wrote:
> >> Here is example/textfile.txt
> >> point    title    description    icon
> >> 10,20    my orange title    my orange description
> >> 2,4    my aqua title    my aqua description
> >> 42,-71    my purple title    my purple description<br/>is
> >> great.    http://www.openlayers.org/api/img/zoom-world-mini.png
> >> You need to add new columns for iconSize and iconOffset, so something
> >> like this:
> >> point    title    description    icon    iconSize    iconOffset
> >> description    http://example.com/icon.jpg    50,50    20,20
> >> On 10/8/07, Tara Athan <tara_athan at alt2is.com> wrote:
> >>>  Erik- sounds good but how do I do that- is there an example
> >>> somewhere to
> >>> follow?
> >>>  Tara
> >>>  Erik Uzureau wrote:
> >>>  Hi Tara,
> >>> What you want to do is to specyify iconOffset and iconSize columns in
> >>> your text file.
> >>> Erik
> >>>  I am trying to add nondefault icons for markers using Layer.Text
> >>> (because I plan to have a large, dynamic set of markers)
> >>> I want the marker to be smaller than the default marker.
> >>> Passing a rescaled version of a larger marker caused it to be enlarged
> >>> and stretched and look really bad.
> >>> I sort of got it working by placing a marker into a larger canvas, but
> >>> the tip of the marker doesn't seem to be in quite the right place.
> >>> Is there some documentation on this, or another way to handle it?
> >>> Also, is there a way to specifiy the image file for all the markers
> >>> in a
> >>> text file without repeating the path in every line?
> >>> Sample script at
> >>> alt2is.com/pages_html/openlayers/marker.html
> >>> Thanks, Tara
> >>> _______________________________________________
> >>> Users mailing list
> >>> Users at openlayers.org
> >>> http://openlayers.org/mailman/listinfo/users
> >>> My e-mail delivery has been unreliable lately, so I am asking for
> >>> return receipts from all my email messages.
> >>> OK'ing the return receipt lets me know that my message was delivered.
> >>> Thank you.
> >>> Tara Athan
> >>> Principal, Alternatives to Invasive Species
> >>> 707-485-1198
> >>> PO Box 415
> >>> Redwood Valley, CA 95470
> >>> Users mailing list
> >> Users mailing list
> Thank you.
> Tara Athan
> 707-485-1198
> PO Box 415
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071010/22f340ff/attachment.html
