[OpenLayers-Users] Measure Distance? Ruler?
Linda_Rawson linda.rawson at gmail.com
Tue Oct 16 13:55:41 EDT 2007
Mike,
I was wondering if you had made progress on this project of yours.
Thanks,
Linda
Mike Adair wrote:
> FYI, I'm hoping to have the Proj4js (or cscs) library finished up in a
> few weeks so you should also be able to use that to convert point coords
> between projections, and do the math in map projected space.
> Proj4js is a port of Proj4 to Javascript, and will use
> spatialreference.org for lookup of projection parameters, if a
> particular projection isn't known already and it includes datum
> transforms.
> Mike
> Erik Uzureau wrote:
>> PS. If anyone is considering building this and would like to share the
>> code with the OL repository, we would (again) be delighted. Please
>> contact me or any of the other PSC members and we can set you up with
>> wiki/trac passwords, access to a sandbox, and help you with
>> code/design decisions.
>> On 8/21/07, Erik Uzureau <erik.uzureau at metacarta.com> wrote:
>>> all:
>>> Here is the official ticket in OL's TRAC for the path measuring tool:
>>> http://trac.openlayers.org/ticket/173
>>> There is also an open ticket for an *area* measuring tool:
>>> http://trac.openlayers.org/ticket/782
>>> Erik
>>> On 8/20/07, Chris Hardin <chrislhardin at gmail.com> wrote:
>>>> It's been quite accurate for me.
>>>> On 8/20/07, Lance Dyas <lancelot at inetnebr.com> wrote:
>>>>> There is accurate distance measurement using the Vincenty distance
>>>>> formula...
>>>>> Haverine is umm simulating the earth as sphere and is not accurate.
>>>>> What Open Layers lacks is a gui for measurement.
>>>> Chris Hardin
>>>> Software Architect
>>>> Archetype Corporation
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Measure-Distance--Ruler--tf4295469.html#a13238902
