[OpenLayers-Users] Way to detect if layer is done loading?
Tim Schaub
tschaub at openplans.org
Wed Oct 17 18:12:55 EDT 2007
Paul Spencer wrote:
> Placing something in the middle is tricky :) In general, you can put
> another element inside the element your map is in ... something like:
> <div id="map">
> <img id="loadingImage" ...>
> </div>
> and in css:
> #loadingImage {
> position: absolute;
> top: 50%;
> left: 50%;
> this isn't exactly in the center though.
Or, if it works to give your map element a background image (I haven't
followed exactly what you're doing) try:
#map {
width: 500px;
height: 500px;
background-image:
url("http://webec.docu-source.com/images/spinner.gif");
background-position: center;
background-repeat: no-repeat;
Tim
> Cheers
> Paul
> On 16-Oct-07, at 9:12 PM, bradleyspencer wrote:
>> Paul,
>> Thanks for your advice it worked a treat.
>> Just one more small question. I want to place this image in the
>> middle of
>> the map which could change if I adopted a fullscreen approach. I
>> can get the
>> lon/lat of the map centre and I can convert that to pixels but it
>> does not
>> seem to be in the middle. Do you know how to do that in OL?
>> Cheers,
>> Brad Spencer
>> http://www.cubewerx.com.au
>> -----Original Message-----
>> From: Paul Spencer [mailto:pagameba at gmail.com]
>> Sent: Wednesday, 17 October 2007 10:12 AM
>> To: brad at cubewerx.com.au
>> Cc: Christopher Schmidt; Edward Fialkowski; users at openlayers.org
>> Subject: Re: [OpenLayers-Users] Way to detect if layer is done
>> loading?
>> Brad,
>> you should be able to do something like this:
>> /* for each layer in onload: */
>> layer.events.register('loadstart', loadStart);
>> layer.events.register('loadend', loadEnd);
>> /* global functions/vars */
>> var layersLoading = 0;
>> function loadStart() {
>> if (layersLoading == 0) {
>> showLoadingImage();
>> layersLoading++;
>> function loadEnd() {
>> layersLoading--;
>> hideLoadingImage();
>> this is rudimentary, untested ...
>> Cheers
>> Paul
>> On 16-Oct-07, at 7:27 PM, bradleyspencer wrote:
>>> I am trying to implement a Loading Image as well. I have managed to
>>> use
>>> LayerLoadMonitoring example to build my own Loading thingy.
>>> See http://demo.cubewerx.com.au/layerload.html
>>> This works fine for single layers as activate the Loading Image as
>>> start of
>>> load and I kill it off once that layer has loaded.
>>> However, if there are multiple layers active and there is a time
>>> difference
>>> between loading layers, the loading image has gone after the first
>>> layer has
>>> completed loading.
>>> I'm not sure how I can modify this to kill off the Loading Image
>>> only after
>>> all layers are loaded.
>>> Can anyone help me here?
>>> Cheers,
>>> Brad Spencer
>>> From: users-bounces at openlayers.org [mailto:users-
>>> bounces at openlayers.org]On
>>> Behalf Of Christopher Schmidt
>>> Sent: Tuesday, 16 October 2007 7:15 AM
>>> To: Edward Fialkowski
>>> Cc: users at openlayers.org
>>> loading?
>>> On Mon, Oct 15, 2007 at 03:16:14PM -0500, Edward Fialkowski wrote:
>>>> Hi List, I would really like to add a loading image to my app to
>>>> show when
>>> a
>>>> layer is still being downloaded, but I'm having difficulty getting
>>>> the
>>> right
>>>> javascript code.
>>>> One option is if it's possible to know in openlayers when a WMS
>>>> image is
>>>> finished downloading and added to the map.
>>>> Has anyone ever tried anything like this?
>>> http://openlayers.org/dev/examples/layerLoadMonitoring.html
>>> Regards,
>>> Christopher Schmidt
>>> MetaCarta
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Chief Technology Officer |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> Users mailing list
> !DSPAM:4033,471605fd106621849620573!
