[OpenLayers-Users] ImageLayer Basic Questions Tilecache and Openlayers
Christopher Schmidt crschmidt at metacarta.com
Thu Oct 18 07:30:37 EDT 2007
On Wed, Oct 17, 2007 at 11:37:52PM -0600, Linda Rawson wrote:
> Christopher,
> I do have PIL installed.  I have a test.py that I make sure it runs with.  I
> had an earlier error because I have a 64 bit operating system but the 32 bit
> version works just fine.  TG.  The building of a 64 bit version of PIL was
> more than I wanted to handle right now.  The image does work when I do not
> specify filebounds.
I'm sorry, I wasn't careful enough last time in reading your post.
The base layer of the map controls the maxExtent. You can not (at this
time) have a layer which has a different maxExtent than your baseLayer
in use with TileCache.
If you make your imagelayer a base layer (drop the
'transparent':'true'), does it work correctly?
Regards,
Christopher Schmidt
MetaCarta
