[OpenLayers-Users] filtering WFS layers
vgvallee vgvallee at hotmail.com
Thu Oct 18 15:00:26 EDT 2007
Lourens Veen-2 wrote:
> ...I've changed the WFS class to accept a "filter" option to which you can
> add an OGC Filter XML filter specification fragment. If you don't, then
> the code will send the BBOX constraint as before, if you do then it
> will combine the fragment with an XML description of the bounding box
> and send it as a FILTER parameter to the WFS server.
That is exactly what I need. I think it should be integrated in the main
code.
View this message in context: http://www.nabble.com/filtering-WFS-layers-tf4401574.html#a13281354
