[OpenLayers-Users] filtering WFS layers
Lourens Veen
veen at science.uva.nl
Fri Oct 19 03:47:49 EDT 2007
On Thursday 18 October 2007 21:00:26 vgvallee wrote:
> Lourens Veen-2 wrote:
> > ...I've changed the WFS class to accept a "filter" option to which you
> > can add an OGC Filter XML filter specification fragment. If you don't,
> > then the code will send the BBOX constraint as before, if you do then it
> > will combine the fragment with an XML description of the bounding box and
> > send it as a FILTER parameter to the WFS server.
> That is exactly what I need. I think it should be integrated in the main
> code.
I have the patch ready to go, I just need to find the right location in the
central bureaucracy to OK the release. Hopefully today still, otherwise it'll
be on Monday.
Lourens
ir. Lourens Veen University of Amsterdam - IBED
Nieuwe Achtergracht 166
Scientific Software Engineer 1018 WV Amsterdam, The Netherlands
EcoGRID-GAN t: +31 20-5257453 f: +31 20-5257431
