[OpenLayers-Users] Problem with addMarker(): OpenLayers 2.4
Nick Whitelegg
nick at hogweed.org
Sun Oct 28 10:29:57 EDT 2007
Hello everyone,
Getting a mysterious problem with addMarker() which I am unable to resolve.
It's on my site, Freemap (www.free-map.org.uk).
If you select "Walk route" mode, you can draw a walk (hiking) route on top of
the map - this uses the OpenLayers Vector drawing facilities. Then, when you
have drawn your walking route, the route appears in red. The user then should
be able to annotate the route by clicking on the map and supplying
annotations (i.e. directions, to help people follow the walk).
Clicking the map brings a dialog box in which the user can supply an
annotation. Clicking Go will send the annotation to the server. When the
response is received, a marker is meant to appear on the map - however it
doesn't, the JavaScript crashes out without an error message. The AJAX
callback function is as follows:
this.annotationAdded = function()
self.ARemovePopup();
var icon = self.walkrouteMarkersLayer.defaultIcon;
var a = self.parent.mapclickpos; // this gives a sensible answer
var b = self.parent.map.getLonLatFromViewPortPx(a); // so does this
var marker = new OpenLayers.Marker(b,icon);
if(self.walkrouteMarkersLayer)
// this if runs
alert('adding marker at lonlat: ' + b);
self.walkrouteMarkersLayer.addMarker(marker);
alert('marker added.');
It fails at the line:
(self is a reference to the current object). Everything else is OK e.g. the
lat/lon is sensible.
I've tracked the error down to the following line in the addMarker() function
of OpenLayers.Layer.Markers:
this.drawMarker(marker);
Strangely the same layer works if I retrieve markers by bounding box.
Any idea what might be happening here? Relevant code:
http://www.free-map.org.uk/freemap/javascript/FreemapClient.js (my 'main'
JavaScript class)
http://www.free-map.org.uk/freemap/javascript/WalkRouteMarkersLayer.js (the
layer I'm adding markers to)
Thanks,
Nick
