[OpenLayers-Users] changing Base layers
bradleyspencer
brad at cubewerx.com.au
Mon Oct 29 21:42:06 EDT 2007
Chris,
I guess I am really dumb but its never clear to me how these different
methods are supposed to be used. I am not a trained OO programmer and find
the documentation a little confusing (my problem :))
So, I tried this: map.setBaseLayer(newBaseLayer)
Where newBaseLayer is the name of the base layer set up at Load time.
This does not work. Am I on the right track here?
Cheers,
Brad Spencer
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Tuesday, 30 October 2007 11:55 AM
To: bradleyspencer
Cc: openlayers users
Subject: Re: [OpenLayers-Users] changing Base layers
On Tue, Oct 30, 2007 at 10:05:40AM +1100, bradleyspencer wrote:
> List,
> Has anybody needed to do this?
> I want to remove the Layerswitcher all together from my map and place
> controls on outside of the map.
> If I had my own radio buttons outside of map for the available base map
> options, is there a standard method to activate the change in base map?
Hm, let's see, a function to change the base layer of the map object...
http://dev.openlayers.org/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Ma
p.setBaseLayer
Regards,
Christopher Schmidt
MetaCarta
