[OpenLayers-Users] changing Base layers
Christopher Schmidt
crschmidt at metacarta.com
Mon Oct 29 22:24:39 EDT 2007
On Tue, Oct 30, 2007 at 12:42:06PM +1100, bradleyspencer wrote:
> Chris,
> I guess I am really dumb but its never clear to me how these different
> methods are supposed to be used. I am not a trained OO programmer and find
> the documentation a little confusing (my problem :))
> So, I tried this: map.setBaseLayer(newBaseLayer)
> Where newBaseLayer is the name of the base layer set up at Load time.
So, if you add two base layers to the map, then doing that should work.
I assume by 'name' you mean 'variable name', rather than anything else.
If all else fails, looking at the code to the layerswitcher mouse
handling methods might help you.
Regards,
Christopher Schmidt
MetaCarta
