[OpenLayers-Users] changing Base layers
bradleyspencer
brad at cubewerx.com.au
Mon Oct 29 23:22:18 EDT 2007
Chris,
I tried looking at the layerswitcher mouse handling code but that was even
more confusing to me :(
I have built a little tester app:
http://demo.cubewerx.com.au/NuMaps/baseLayerTest.html
Can you just have a quick look at this for me its probably going to
something very simple. I'd appreciate it.
Cheers,
Brad
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Tuesday, 30 October 2007 1:25 PM
To: bradleyspencer
Cc: openlayers users
Subject: Re: [OpenLayers-Users] changing Base layers
On Tue, Oct 30, 2007 at 12:42:06PM +1100, bradleyspencer wrote:
> Chris,
> I guess I am really dumb but its never clear to me how these different
> methods are supposed to be used. I am not a trained OO programmer and find
> the documentation a little confusing (my problem :))
> So, I tried this: map.setBaseLayer(newBaseLayer)
> Where newBaseLayer is the name of the base layer set up at Load time.
So, if you add two base layers to the map, then doing that should work.
I assume by 'name' you mean 'variable name', rather than anything else.
If all else fails, looking at the code to the layerswitcher mouse
handling methods might help you.
Regards,
Christopher Schmidt
MetaCarta
