[OpenLayers-Users] changing Base layers
Brent Pedersen bpederse at gmail.com
Mon Oct 29 23:27:50 EDT 2007
change this:
map.setBaseLayer(newBaseLayer);
to this:
map.setBaseLayer(window[newBaseLayer]);
you need the variable, not hte string.
On 10/29/07, bradleyspencer <brad at cubewerx.com.au> wrote:
> Chris,
> I tried looking at the layerswitcher mouse handling code but that was even
> more confusing to me :(
> I have built a little tester app:
> http://demo.cubewerx.com.au/NuMaps/baseLayerTest.html
> Can you just have a quick look at this for me its probably going to
> something very simple. I'd appreciate it.
> Cheers,
> Brad
> -----Original Message-----
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: Tuesday, 30 October 2007 1:25 PM
> To: bradleyspencer
> Cc: openlayers users
> Subject: Re: [OpenLayers-Users] changing Base layers
> On Tue, Oct 30, 2007 at 12:42:06PM +1100, bradleyspencer wrote:
> > Chris,
> > I guess I am really dumb but its never clear to me how these different
> > methods are supposed to be used. I am not a trained OO programmer and
> find
> > the documentation a little confusing (my problem :))
> > So, I tried this:   map.setBaseLayer(newBaseLayer)
> > Where newBaseLayer is the name of the base layer set up at Load time.
> So, if you add two base layers to the map, then doing that should work.
> I assume by 'name' you mean 'variable name', rather than anything else.
> If all else fails, looking at the code to the layerswitcher mouse
> handling methods might help you.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071029/3cc8502d/attachment.html
