[OpenLayers-Users] OverviewMap does not work with examples.
samd
sdoyle_2 at yahoo.com
Tue Oct 30 21:06:27 EDT 2007
Nobody?
samd wrote:
> OpenLayers 2.5
> As taken directly from the OpenLayers examples and my map is named map
> when ever I add the following code:
> var options = {mapOptions: {numZoomLevels: 1}};
> map.addControl(new OpenLayers.Control.OverviewMap(options));
> I always end up with:
> bounds has no properties
> zoomTo(null)OpenLayers.js (line 533)
> zoomToMaxExtent()OpenLayers.js (line 535)
> createMap()OpenLayers.js (line 408)
> rectDblClick()OpenLayers.js (line 405)
> remove("moveend", Object object=Object element=div#map)OpenLayers.js (line
> 365)
> getCenter(lon=-122.297916,lat=37.844969 lon=-122.297916 lat=37.844969, 11,
> undefined, undefined)
> When I remove the offending lines everything works fine as
> usual!?:confused:
View this message in context: http://www.nabble.com/OverviewMap-does-not-work-with-examples.-tf4719927.html#a13501153
