[OpenLayers-Users] Suppressing layers from being loaded
Christopher Schmidt crschmidt at metacarta.com
Wed Oct 31 21:44:39 EDT 2007
On Wed, Oct 31, 2007 at 04:55:05PM -0400, Jeff Yutzler wrote:
> I have a Layer that renders feature data from a richly populated
> datastore.  The problem is that at large scale, a Get Image operation is
> expensive but I can't seem to prevent the Get Image operation from
> occurring.  In an attempt to avoid the problem, I set {visibility:
> false} in the options when I instantiate the layer object, but this had
> no effect.  I have confirmed that the parameter has made its way to
> div.style.display = "none".  However, I see that Firefox is still
> attempting to load the image.  This is bad.  (FWIW, this layer extends
> Grid, but this problem would presumably occur on any layer type.)
What happens if you do setVisibility(false); instead of setting the
visibility yourself?
Does it continue to load as you change zooms more than once?
It's possible this is part of an already-reported bug, or possibly a new
bug report I'm not yet aware of.
Regards,
Christopher Schmidt
MetaCarta
