[OpenLayers-Users] Suppressing layers from being loaded
Leandro R
learonco at gmail.com
Wed Oct 31 21:37:27 EDT 2007
Hello!!
Have you tried with minScale and maxScale properties in the layer?
Regards
Leandro
2007/10/31, Jeff Yutzler <jeff.yutzler at ionicenterprise.com>:
> I have a Layer that renders feature data from a richly populated
> datastore. The problem is that at large scale, a Get Image operation is
> expensive but I can't seem to prevent the Get Image operation from
> occurring. In an attempt to avoid the problem, I set {visibility:
> false} in the options when I instantiate the layer object, but this had
> no effect. I have confirmed that the parameter has made its way to
> div.style.display = "none". However, I see that Firefox is still
> attempting to load the image. This is bad. (FWIW, this layer extends
> Grid, but this problem would presumably occur on any layer type.)
> I have reworked things to not put this particular layer in the map, but
> there are times where it would be nice to be able to do so. Is there
> any way to reliably suppress a layer from being loaded?
> I'm working off of 2.4, but I do not believe anything has changed in
> this area in the meantime.
> Thanks.
> -Jeff
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071031/9dd4a2d8/attachment.html
