[OpenLayers-Users] dragmakerer
Paul Stanton
paul.stanton at gunnsoft.com.au
Wed Oct 31 18:00:57 EDT 2007
Thanks Tim, Believe me I would if I could find time!
I've noticed the drag marker demo does not work whatsoever in IE 6,
however the drag feature one does. Is this due to recieve any attention
soon or should I look into using the drag feature code instead?
Obviously I understand that you have plenty of other things to do, and
this is probably a low priority feature.
Regards, Paul.
Tim Schaub wrote:
> We need to make some improvements and write some tests for this still.
> If you are interested in seeing it done, you could take a look at how
> our test stuff works.
> Tim
> Paul Stanton wrote:
>> Hi guys,
>> I stumbled upon the dragmarker demo:
>> http://dev.openlayers.org/sandbox/tschaub/feature/examples/drag-marker.html
>> The objects it uses (Handler.Marker, Control.DragMarker) aren't in the
>> svn trunk yet, does anyone know where they are at? ie are they going to
>> be included soon?
>> Thanks, Paul.
