[OpenLayers-Users] dragmakerer
Paul Stanton paul.stanton at gunnsoft.com.au
Wed Oct 31 23:39:36 EDT 2007
on further inspection, it appears it's to do with the calculation of the
region attributed to the marker. I can get it to drag from a minuscule
region in the top left hand corner of the marker in IE.
Paul Stanton wrote:
> Thanks Tim, Believe me I would if I could find time!
> I've noticed the drag marker demo does not work whatsoever in IE 6,
> however the drag feature one does. Is this due to recieve any attention
> soon or should I look into using the drag feature code instead?
> Obviously I understand that you have plenty of other things to do, and
> this is probably a low priority feature.
> Regards, Paul.
> Tim Schaub wrote:
>> We need to make some improvements and write some tests for this
>> still. If you are interested in seeing it done, you could take a look
>> at how our test stuff works.
>> Tim
>> Paul Stanton wrote:
>>> Hi guys,
>>> I stumbled upon the dragmarker demo:
>>> http://dev.openlayers.org/sandbox/tschaub/feature/examples/drag-marker.html
>>> The objects it uses (Handler.Marker, Control.DragMarker) aren't in
>>> the svn trunk yet, does anyone know where they are at? ie are they
>>> going to be included soon?
>>> Thanks, Paul.
