[OpenLayers-Users] Destroy not being called for popups?
Erik Uzureau
erik.uzureau at metacarta.com
Mon Sep 3 11:00:02 EDT 2007
Perhaps it would be worth considering adding "open" and "close"
methods to the popup's events object. probably not something to do
until 2.6 though. let's keep cleaning house until we can get an RC on
2.5
E
On 9/3/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Mon, Sep 03, 2007 at 11:20:14AM +1000, Glen Stampoultzis wrote:
> > On 31/08/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > > On Fri, Aug 31, 2007 at 04:12:54PM +1000, Glen Stampoultzis wrote:
> > > > Hi...
> > > > just been mucking around with popups and I noticed that the destroy
> > > method
> > > > does seem to get called. The close poup button just hides the div from
> > > what
> > > > I can tell and the map.removePopup() call seems to remove the div from
> > > the
> > > > DOM without calling destroy and cleaning up the event handlers.
> > > > Bug or feature?
> > > When would you call destroy? Certainly, a popup can be removed from the
> > > map without it being destroyed: it can be re-added at a later time, and
> > > we use that behavior in some applications here at MetaCarta.
> > > In general, removing things is not the same as destroying them, and
> > > depending on when they are created, you may have to clean up after
> > > yourself rather than depending on OpenLayers to do it for you.
> > > If you use a feature to create the popup, it destroys the popup for
> > > you. If you create your own, you're on your own.
> > It's just that popup doesn't provide any way for you to attach an event
> > indicating the user has closed the popup using the close button so how do
> > you know when to destroy?
> You probably don't want to destroy when the user closed the popup
> anyway: It's still attached to the map at that point, no?
> One possibility is just to destroy it when the window is closed -- but
> really, if there's still any popups on the map when the page is
> unloaded, we should be destroying them. I've opened ticket #955 for
> that. Would that be enough to solve the problem? Is destroying the
> popups during your application's running important?
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
