[OpenLayers-Users] Destroy not being called for popups?
Glen Stampoultzis
gstamp at gmail.com
Mon Sep 3 22:29:21 EDT 2007
On 04/09/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Mon, Sep 03, 2007 at 11:20:14AM +1000, Glen Stampoultzis wrote:
> > On 31/08/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > > On Fri, Aug 31, 2007 at 04:12:54PM +1000, Glen Stampoultzis wrote:
> > > > Hi...
> > > > just been mucking around with popups and I noticed that the destroy
> > > method
> > > > does seem to get called. The close poup button just hides the div
> from
> > > what
> > > > I can tell and the map.removePopup() call seems to remove the div
> from
> > > the
> > > > DOM without calling destroy and cleaning up the event handlers.
> > > > Bug or feature?
> > > When would you call destroy? Certainly, a popup can be removed from
> the
> > > map without it being destroyed: it can be re-added at a later time,
> and
> > > we use that behavior in some applications here at MetaCarta.
> > > In general, removing things is not the same as destroying them, and
> > > depending on when they are created, you may have to clean up after
> > > yourself rather than depending on OpenLayers to do it for you.
> > > If you use a feature to create the popup, it destroys the popup for
> > > you. If you create your own, you're on your own.
> > It's just that popup doesn't provide any way for you to attach an event
> > indicating the user has closed the popup using the close button so how
> do
> > you know when to destroy?
> You probably don't want to destroy when the user closed the popup
> anyway: It's still attached to the map at that point, no?
> One possibility is just to destroy it when the window is closed -- but
> really, if there's still any popups on the map when the page is
> unloaded, we should be destroying them. I've opened ticket #955 for
> that. Would that be enough to solve the problem? Is destroying the
> popups during your application's running important?
It would help. I guess I'm a bit anal about leaving loads of unnecessary
event handlers registered for popups that aren't visible. I can do a check
for hidden popups before opening a new one I guess.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070904/39476bc1/attachment.html
