[OpenLayers-Users] Handler problems
Tom (JDi Solutions)
tom.dean at jdi-solutions.co.uk
Tue Sep 4 11:14:42 EDT 2007
Excellent, thanks. I've requested a password for trac but haven't received
one yet, does it normally take this long?
Also, any ideas how I can workaround this problem or am I going to have to
use an old style click event?
On 9/4/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Sep 04, 2007 at 09:39:08AM +0100, Tom (JDi Solutions) wrote:
> > Looks like this is a bug in OpenLayers.
> > It works fine in IE6 & IE7. Only FF shows this bug.
> > 2 example pages show this working and not working:
> > Here is a slight adaptation of the examples/custom-control.htmlfile. The
> > only difference from the original being that instead of alerting the
> results
> > it displays them in a div immediately below the map div. It works
> > perfectly. :)
> > http://demo.jdi-consult.net/oltest/custom-control-box.html
> > In this example there is one further change from the example above. The
> > handler has been changed from Box to Point. Now if you shift click the
> map
> > the co-ords are displayed below the map as before, if you then shift
> click
> > outside the map div the co-ords are recalculated and displayed. This
> should
> > not happen! Further clicks outside the map do not trigger the handler.
> > http://demo.jdi-consult.net/oltest/custom-control-point.html
> > Can someone please confirm this, is there a quick fix? Shall I add it
> to
> > JIRA?
> Trac :) Yes please. http://trac.openlayers.org/wiki/FilingTickets . Dump
> it in the 2.5 milestone , though I'm not sure it will get fixed there:
> I'm hoping Tim will get a chance to look at it and offer feedback (which
> may just be "Firefox is stupid and returning events when it shouldn't",
> which is my personal guess....)
> Thanks for the report.
> Regards,
> Christopher Schmidt
> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070904/9a8ae9e7/attachment.html
