[OpenLayers-Users] Problem in Internet Explorer
Tyler Durden
tylersticky at gmail.com
Wed Sep 12 09:36:10 EDT 2007
You are right Christopher.
I'm using jquery $(document).ready(function() {} and seems that won't
work, with <body initMap()> works.
Thanks,
Tyler
On 9/11/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Sep 11, 2007 at 05:56:51PM +0100, Tyler Durden wrote:
> > I've got a javascript error on Internet Explorer on line 50 in the
> > file OpenLayers/Renderer/VML.js:
> > * @returns Whether or not the browser supports the VML renderer
> > * @type Boolean
> > supported: function() {
> > var supported = document.namespaces;
> > return supported;
> > I'm using the trunk version.
> > Any ideas?
> My first guess is that you're attempting to start using the OpenLayers
> code before the document is fully loaded. Although most of OpenLayers
> will work that way, we advise against it, and it won't work with VML in
> OpenLayers.
> Is this possible? If you don't think so, could you provide HTML which is
> causing the problem?
> Regards,
> Christopher Schmidt
> MetaCarta
