[OpenLayers-Users] Fixing Google Layers, OL SVN + OL <= 2.4
Christopher Schmidt
crschmidt at metacarta.com
Tue Sep 18 16:38:36 EDT 2007
On Tue, Sep 18, 2007 at 01:37:21PM -0700, samd wrote:
> this.b.firstChild is null or not an object
> The same code works fine with GeoServer WMS
SD --
We've already identified the problem, and the solution, as described in
the code. Are you saying that the fix does not work for you? Can you
share an example?
Regards,
Christopher Schmidt
MetaCarta
