[OpenLayers-Users] Fixing Google Layers, OL SVN + OL <= 2.4
samd
sdoyle_2 at yahoo.com
Tue Sep 18 16:46:24 EDT 2007
Yes Chris,
I added the change you mentioned to the start of my onload routine before
the map/layers are created but the JavaScripts are loaded.
S.D.
You can see on our demo box:
http://64.237.5.34/ilda/
This version doesn't include the fix but I have applied the fix you have
mentioned on my development box and the exact same error still occurs.
My onLoad function starts like this:
function initILDA()
// Google Layer Patch
GMap2.prototype.fromLatLngToContainerPixel = function(gLatLng) {
// first we translate into "DivPixel"
var gPoint = this.fromLatLngToDivPixel(gLatLng);
// locate the sliding "Div" div
var div = this.getContainer().firstChild.firstChild;
// adjust by the offset of "Div" and voila!
gPoint.x += div.offsetLeft;
gPoint.y += div.offsetTop;
return gPoint;
Christopher Schmidt-4 wrote:
> On Tue, Sep 18, 2007 at 01:37:21PM -0700, samd wrote:
>> this.b.firstChild is null or not an object
>> The same code works fine with GeoServer WMS
> SD --
> We've already identified the problem, and the solution, as described in
> the code. Are you saying that the fix does not work for you? Can you
> share an example?
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Fixing-Google-Layers%2C-OL-SVN-%2B-OL-%3C%3D-2.4-tf4476705.html#a12765790
