[OpenLayers-Users] XML / GeoRSS / GML / KML and combined layers
(Markers & SVG)
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Sep 19 05:52:10 EDT 2007
Wrt your last question, a colleague of mine has done an implementation of a
Group layer, which can be found here:
http://www.osgis.nl/download/Group.js
Example useage:
var groupLayer = new OpenLayers.Layer.Group("My group layer", {});
map.addLayer(groupLayer);
groupLayer.addLayer(layerA);
groupLayer.addLayer(layerB);
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: mike <mike at bristolbeat.co.uk>
Naar: users at openlayers.org <users at openlayers.org>
Onderwerp: [OpenLayers-Users] XML / GeoRSS / GML / KML and combined layers
(Markers & SVG)
Datum: 19/09/07 07:44
> Hi,Is there any documentation of the merits / purpose and intended future
developments of the various XML layers such as GeoRSS, GML, KML etc?They
seem to be very similar and almost interchangable, and I'm finding this
a bit confusing.
> For example, I'm using GeoRSS to draw markers, and KML to draw
lines. However, this excellent GeoRSS Serialise example seems to be an
edit / draw component for lines and polys:
http://dev.openlayers.org/sandbox/ahocevar/sldRenderer/examples/georss-serialize.html
Equally, KML boasts support for styles, although this is not implemented
yet, and if we are accepting the Google definition, then KML should support
both markers and lines / polys.
> Is there a twiki page for this or a good resource I could refer to?
I'm considering developing this further and I'd like to make sure
I'm doing the right thing before I start... Also if anyone if
actively developing in this area I'd be very interested to discuss and
see if I can help.
> My other point is about combined layers - I'd like to create a layer
in the layerswitcher which shows markers and lines / polys (i.e. SVG I
assume). Is it possible to make a combined layer or wrap two layers
into one in some way?
> cheers, mike
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
