[OpenLayers-Users] Layer: Name and Title
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Sep 21 09:37:51 EDT 2007
I think I understand your confusion although this adds to my confusion :-).
It comes from the OGC world where a Layer has a Name and Title, where a name
is more cryptic and a title is more descriptive.
But if I get it right the OpenLayers name is actually the OGC title ... and
layers are never identified by its name but only by its object
representation.
So there shouldn't be any problem in fact, except that the current
LayerSwitcher does not deal correctly I think with layers that have the same
name, since the ids of the input elements will be the same in that case, or
am I mistaken?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Christopher Schmidt <crschmidt at metacarta.com>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: users at openlayers.org
Onderwerp: Re: [OpenLayers-Users] Layer: Name and Title
Datum: 21/09/07 11:16
> On Fri, Sep 21, 2007 at 02:08:30PM +0200, Bart van den Eijnden (OSGIS)
wrote:
> > Hi list,
> > currently an OpenLayers Layer object only has a name property, and
this is
> > used for display.
> > If you would introduce the concept of group layers, you could have
the
> > situation where you want to give the same name to multiple layers
(since
> > this is also displayed in the GUI).
> > Would it not be better to have both a title and name property on the
Layer
> > object?
> I'm confused.
> 1. I don't think more than one 'name for display purposes' should be
> required.
> 2. Any property sent in the options for a layer is set as a property
> on that layer, which can be taken advantage of by any controls, etc.
> (See attribution.html example, for example.)
> 3. I don't see what UI element would display anything other than
> 'name' with the current code.
> Regards,
> Christopher Schmidt
> MetaCarta
