[OpenLayers-Users] loading XML problem
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Mon Sep 24 10:35:17 EDT 2007
Hi list,
I've got a problem when I load an XML file using OpenLayers, that when
parsing IE complains about the special characters in there, though the
encoding is set to ISO-8859-1 in the XML header.
This works fine (result = true):
var url = 'http://www.osgis.nl/download/weggeg.xml';
var xmlDoc=new ActiveXObject("Microsoft.XMLDOM");
xmlDoc.async=false;
result = xmlDoc.load(url);
Whereas this does not work (result = false):
OpenLayers.loadURL(url, null, this, parseGetCapabilities);
function parseGetCapabilities(ajaxRequest)
var text = ajaxRequest.responseText;
xmlDoc.async=false;
result = xmlDoc.loadXML(text);
result is false in this case with the parsing error pointing to the special
character.
Is there anything in OL that sets things to UTF-8 or something similar?
Any pointers appreciated!
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
