[OpenLayers-Users] loading XML problem
Andrew Larcombe
andrew at andrewlarcombe.co.uk
Mon Sep 24 17:44:03 EDT 2007
On 24 Sep 2007, at 15:35, Bart van den Eijnden (OSGIS) wrote:
> This works fine (result = true):
> var url = 'http://www.osgis.nl/download/weggeg.xml';
> var xmlDoc=new ActiveXObject("Microsoft.XMLDOM");
> xmlDoc.async=false;
> result = xmlDoc.load(url);
> Whereas this does not work (result = false):
> OpenLayers.loadURL(url, null, this, parseGetCapabilities);
> function parseGetCapabilities(ajaxRequest)
> var text = ajaxRequest.responseText;
> xmlDoc.async=false;
> result = xmlDoc.loadXML(text);
> result is false in this case with the parsing error pointing to the
> special
> character.
The difference looks to be in that in the first case the ActiveX
control loads the contents of the xml file, whilst in the second it
is passed the contents of the xml file as held in a variable. If the
process of reading that file's contents into the variable munge up
the xml somehow then that might be where your problem is.
Can you attempt to further isolate the problem outside of OL by
creating an AJAX request to your url, storing it in a variable, then
loading it into the activex control using loadXML.
Cheers,
Andrew
Andrew Larcombe
Freelance Geospatial, Database & Web Programming
web: http://www.andrewlarcombe.co.uk
email: andrew at andrewlarcombe.co.uk
icq: 306690163
