[OpenLayers-Users] WMS layer is shifted from VE
Chris Holmes
cholmes at openplans.org
Thu Sep 27 01:35:54 EDT 2007
Note that GeoServer 1.5.3 out of the box has a slight error in that
reprojection. 1.5.4 will have the fix, but we waited to see if there
were other small ones to make, and then got wrapped up in conference prep.
If you want a GeoServer that works right with 900913 try out 1.6-beta3.
It may fix the problem (though it may just be the other problems).
Chris
Leandro R wrote:
> Thanks.
> I'm using the reproject flag on a EPSG:4326 wms layer, not in a
> Layer.SpericalMercator or "commercial layers". I want to reproject from
> EPSG:4326 to EPSG:900913.
> Does OpenLayers use the projection of the map on the GetMap
> request?...so all the layers can lineup correctly.
> If the answer is true, would not be the server that makes the
> reprojection and send the "reprojected" image to the client?
> The layers and the map should have the same projection?.
> I'm starting with this, and as you can see I have a lot of doubts.
> Thanks for answer.
> !DSPAM:4005,46fafb79137001012714783!
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070926/ac635808/cholmes.vcf
