[OpenLayers-Users] WMS layer is shifted from VE
Leandro R learonco at gmail.com
Thu Sep 27 11:19:23 EDT 2007
Thanks...
Do you know how can I fix GeoServer to get this work?
Should I look in the GeoServer mailing list :)
2007/9/27, Chris Holmes <cholmes at openplans.org>:
> Note that GeoServer 1.5.3 out of the box has a slight error in that
> reprojection.  1.5.4 will have the fix, but we waited to see if there
> were other small ones to make, and then got wrapped up in conference prep.
> If you want a GeoServer that works right with 900913 try out 1.6-beta3.
>   It may fix the problem (though it may just be the other problems).
> Chris
> Leandro R wrote:
> > Thanks.
> > I'm using the reproject flag on a EPSG:4326 wms layer, not in a
> > Layer.SpericalMercator or "commercial layers". I want to reproject from
> > EPSG:4326 to EPSG:900913.
> > Does OpenLayers use the projection of the map on the GetMap
> > request?...so all the layers can lineup correctly.
> > If the answer is true, would not be the server that makes the
> > reprojection and send the "reprojected" image to the client?
> > The layers and the map should have the same projection?.
> > I'm starting with this, and as you can see I have a lot of doubts.
> > Thanks for answer.
> > !DSPAM:4005,46fafb79137001012714783!
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070927/8a69d3f3/attachment.html
