[OpenLayers-Users] RC 2.5-RC3 Problem with Boxes
Christopher Schmidt
crschmidt at metacarta.com
Thu Sep 27 16:34:42 EDT 2007
On Thu, Sep 27, 2007 at 12:48:03PM -0600, Linda Rawson wrote:
> That would be fine if I was only drawing one box. My problem is I need to
> draw hundreds of them and they don't appear at the right location. Their
> height is off. The width appears to be fine but the height is not offset.
> I still think there is a bug here. I provided a very simple example. If
> the box is the same bounds as the viewport then why isn't the box the same
> size? It appears to have a problem with the sizing.
I'd recommend not using a Boxes layer. Instead, use a Vector layer and
draw a polygon.
The boxes layer is, to be honest, bad. It's around because it has always
been around, but I don't think it's ever worked.
Regards,
Christopher Schmidt
MetaCarta
