[OpenLayers-Users] trouble with WFS and Mapserver
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Fri Sep 28 15:06:25 EDT 2007
Still trying, and have no joy from the WFS layer.
I set the isBaseLayer: true, and this succeeded in removing the issue surrounding the javascript maxExtent error.
I verified my projection info, wfs_srs and wms_srs are set to EPSG:4326, and my layer projection is now set to "init:EPSG:4326", however, I still get a blank map.  My firebug skills are virtually non-existent, and I have stumbled around, failing to locate the request for the WFS-layer as Arnd recommended.
At this point, I am totally flailing (and failing).  Other details that might prove relevant, Mapserver 4.10 on windows, and as mentioned before, I get a properly formed XML document with all shape info and column values and attributes when doing an URL getFeature request.
Can anyone who has set up a mapserver WFS request in OL possibly post the relevant excerpts from their map file, and javascript calls?
I am somewhat at a loss as to other parameters, having tried the request with and without "featureClass: OpenLayers.Feature.WFS" in the additional parameters field.
Thanks!
r.b.
-----Original Message-----
From: arnd.wippermann at web.de [mailto:arnd.wippermann at web.de]
Sent: Thursday, September 27, 2007 4:58 PM
To: Burgholzer,Robert
Cc: users at openlayers.org
Subject: AW: [OpenLayers-Users] trouble with WFS and Mapserver
when you use FF with firebug, you can get the request for the WFS-layer. Something like this:
http://geturl.asp?http%3A//localhost/mapserv.exe%3Fmap%3DTreppen.map <http://geturl.asp?http%3A/localhost/mapserv.exe%3Fmap%3DTreppen.map>
%26typename%3DPOI
%26maxfeatures%3D10
%26SERVICE%3DWFS
%26VERSION%3D1.0.0
%26REQUEST%3DGetFeature
%26SRS%3DEPSG%253A4326
%26BBOX%3D6.416875%2C50.556875%2C7.823125%2C51.963125
Retrieve the Url with your Internet Explorer and you should get some xml. If not than i would think your proxy is not right or your mapfile. If you cut the SRS and BBOX from the Url and then get an answer, it looks like you have a problem with the projections in your mapfile.
To get my own WFS-layer working, i have learned
1. if the SRS in the request is the same as the WFS-layer, I only have to declare a projection in the layer block
2. if the SRS in the request is different from the WFS-layer, I have to declare the requested SRS as 'wfs_srs'  'EPSG:xxxx' in the WEB block and the projection in the LAYER block of the WFS-layer. Then my data will reproject and show in OpenLayers.
You have also declare 'wms_srs' in the WEB block for the requested SRS.
What I not understand, is, when I'm right with my mapfile, I must have for different requested SRS an own mapfile.
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
  _____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im Auftrag von Burgholzer,Robert
Gesendet: Donnerstag, 27. September 2007 22:06
An: users at openlayers.org
Betreff: [OpenLayers-Users] trouble with WFS and Mapserver
I am having a hard time getting my mapserver to serve up WFS layers (or accessing them via OpenLayers, I really don't know which).
I have tested the mapserver with WMS, and all is good. I am able to retrieve WFS data from mapserver via an URL request for getfeature, however, I get no success when trying to load it into openlayers via WFS, just a blank map.  In the javascript error console, all I get is an error that the "maxExtent has no properties", indicating that there are no valid layers, I assume, which is of course evidenced by the fact that my map is blank.
My creation statement and mapserver layer description is as follows:
OL:
            layer1 = new OpenLayers.Layer.WFS( "poli_bounds",
                    url, {'typename': 'poli_bounds'},
                      typename: 'poli_bounds',
                      featureNS: 'http://www.openplans.org/topp',
                      extractAttributes: false
MAPFILE:
LAYER
   CONNECTIONTYPE postgis
   CONNECTION "host=localhost user=postgres password=*** dbname=wsp"
   NAME poli_bounds
   GROUP poli_bounds
   TYPE POLYGON
   STATUS DEFAULT
   DUMP TRUE
   DATA "the_geom from poli_bounds"
   FILTER "1 = 1"
   TEMPLATE drought.html
   #MINSCALE 1000
   #MAXSCALE 50000
   LABELITEM "name"
   CLASS
      NAME "Political Boundaries"
      SYMBOL 'circle'
      SIZE 3
      COLOR -1 -1 -1
      BACKGROUNDCOLOR 0 0 0
      OUTLINECOLOR 0 0 0
      LABEL
        COLOR 8 8 174
        #SHADOWCOLOR 218 218 218
        #SHADOWSIZE 2 2
        TYPE TRUETYPE
        FONT arial
        SIZE 7
        ANTIALIAS TRUE
        POSITION CC
        PARTIALS FALSE
        MINDISTANCE 300
        MINFEATURESIZE 30
        BUFFER 4
        #MINSCALE 1000
        #MAXSCALE 50000
      END # end of label
   END
   TOLERANCE 10
   PROJECTION
   # EPSG SRID = 4326
     "proj=latlong"
   END
   METADATA
    "DESCRIPTION"   "Political Boundaries"
    "RESULT_FIELDS" "name county state"
    "wfs_title"    "poli_bounds" ## REQUIRED
    "gml_featureid" "gid" ## REQUIRED
    "gml_include_items" "all"  ## Optional (serves all attributes for layer)
      "title" "Political Boundaries"
      "tablename" "Political Boundaries"
   END
END
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
Web-Based Water Supply Planning Demo:
http://soulswimmer.dynalias.net/models/wsdemo/demo_hsi.php
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070928/a265d9aa/attachment.html
