[OpenLayers-Users] Controls not working
Christopher Schmidt crschmidt at metacarta.com
Wed Apr 2 07:38:53 EDT 2008
On Wed, Apr 02, 2008 at 08:47:56AM +0200, Frédéric Junod wrote:
> Hi,
> You can't use the ScaleLine control because you're using and old version of
> OpenLayers (http://www.openlayers.org/api/OpenLayers.js version 2.5). The
> ScaleLine control was added after the 2.5 release.
> You have to use a more recent version of OpenLayers, the new stable release is
> not ready yet but you can use the release candidate:
> http://openlayers.org/api/2.6-rc1/OpenLayers.js
> But this is not the final code !! When the final 2.6 will be released this url
> will become obsolete ...
Nothing in /api/ Ever goes away: You can continue to use 2.6-rc1 for all
time, but it would not be wise to. However, it's only obsolete in the
same way that /api/2.4/ is: You can safely use this in your application,
you should just be aware that as soon as 2.6 is released, it will make
sense for you to switch.
Regards,
Christopher Schmidt
MetaCarta
