[OpenLayers-Users] GDAL2Tiles
Bjorn Sandvik B.Sandvik at sms.ed.ac.uk
Wed Apr 2 16:17:20 EDT 2008
Wow - it works!
http://www.thematicmapping.org/openlayers/fullscreen.htm
Thanks a lot! OpenLayers keeps impressing me.
And, I'm often very confused ;-)
Bjorn
http://blog.thematicmapping.org
Christopher Schmidt wrote:
> On Wed, Apr 02, 2008 at 07:54:20PM +0100, Bjorn Sandvik wrote:
>> This is the code generated by gdal2tiles:
>> http://www.thematicmapping.org/maptiles/naturalearth/openlayers.html
>> Only pixel based view is supported, which makes is difficult to combine
>> map tiles with other data layers.
> I saw this same thing mentioned in some blog posting somewhere, and I
> thought "huh, someone is confused": in fact, this lines up exactly with
> the TMS spec, and can be used with practically no changes by the default
> TMS layer:
> http://crschmidt.net/mapping/naturalearth.html
>  You just need to specify a serviceVersion of '.' .  (This is pulled
>  almost exactly from the TMS example that ships with OpenLayers.)
>> Is there an alternative way of loading map tiles?
> Other than the TMS layer?
>> Or is there a better alternative to gdal2tiles?
> None needed, so far as I can tell.
> Regards,
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
