[OpenLayers-Users] Busy Cursor
Carlos Pinto cmspinto at gmail.com
Wed Apr 9 07:41:09 EDT 2008
Hi all,
I am using the library "<script  src="
http://www.openlayers.org/dev/lib/OpenLayers.js"></script>"
but I have seen this post and I thought that is really a good idea to put a
loading panel but when I had the line:
map.addControl( new OpenLayers.Control.LoadingPanel({minSize: new
OpenLayers.Size(600, 600)}) );
the map don't appear!!!!!!
Is it because of the openlayers version I am using?
Thanks
Carlos
On Wed, Apr 9, 2008 at 9:32 AM, Bart van den Eijnden (OSGIS) <
bartvde at osgis.nl> wrote:
> Hi Linda,
> you could have a look at the LoadingPanel Control. Something similar could
> be done to change the map cursor.
> See:
> http://trac.openlayers.org/ticket/102
> and:
> http://trac.openlayers.org/browser/sandbox/bartvde/loadingpanel/lib/OpenLayers/Control/LoadingPanel.js
> In maximizeControl you could set the busy mouse cursor on the map div, and
> in minimizeControl change the cursor back.
> example:
> http://dev.openlayers.org/sandbox/bartvde/loadingpanel/examples/loadingpanel.html
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Linda Rawson <linda.rawson at gmail.com>
> Naar: OpenLayers Users <users at openlayers.org>
> Onderwerp: [OpenLayers-Users] Busy Cursor
> Datum: 09/04/08 01:05
> > I have two layers that when I switch between them the performance is
> > so bad that there is a noticeable delay.  How would I implement an
> > hourglass cursor to indicate to the user that the application is
> > working and then put the cursor back to normal when the layer is
> > loaded.
> > Linda Rawson
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080409/b37f20ca/attachment.html
