[OpenLayers-Users] Busy Cursor
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Wed Apr 9 03:32:58 EDT 2008
Hi Linda,
you could have a look at the LoadingPanel Control. Something similar could
be done to change the map cursor.
See:
http://trac.openlayers.org/ticket/102
and:
http://trac.openlayers.org/browser/sandbox/bartvde/loadingpanel/lib/OpenLayers/Control/LoadingPanel.js
In maximizeControl you could set the busy mouse cursor on the map div, and
in minimizeControl change the cursor back.
example:
http://dev.openlayers.org/sandbox/bartvde/loadingpanel/examples/loadingpanel.html
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Linda Rawson <linda.rawson at gmail.com>
Naar: OpenLayers Users <users at openlayers.org>
Onderwerp: [OpenLayers-Users] Busy Cursor
Datum: 09/04/08 01:05
> I have two layers that when I switch between them the performance is
> so bad that there is a noticeable delay.  How would I implement an
> hourglass cursor to indicate to the user that the application is
> working and then put the cursor back to normal when the layer is
> loaded.
> Linda Rawson
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
