[OpenLayers-Users] Strange behavior with LineString feature on Vector Layer with 2.6 Trunk IE only
Christopher Schmidt crschmidt at metacarta.com
Thu Apr 10 11:16:15 EDT 2008
On Thu, Apr 10, 2008 at 08:04:16AM -0600, Linda Rawson wrote:
> This is new in 2.6.  It does not happen in 2.5.  The only thing that I
> notice is that the lines are thicker in 2.5 and I don't know if that
> is what is making the difference.  I am trying to come up with an
> example but I have lots of layers and I have yet to figure out what is
> causing the problem.  I had a similar problem in 2.5 when the minimum
> resolution was not setting on calculateinrange on the layer.  But that
> is not the problem with 2.6.  It is as though at the higher zoom
> levels the lines just can't show up because they are being resized too
> small.  Markers show up just fine but the vector lines do not.
For the record, I've just tried this in IE6 and IE7 (putting a linear
vector feature on top of a map, setting numZoomLevels to 20, and zooming
far in) and had no problems.
(Thanks for yoru continuned bug finding efforts!)
Regards,
Christopher Schmidt
MetaCarta
