[OpenLayers-Users] Tilecache layer temporary patch
Simone Gadenz
simone.gadenz at jrc.it
Thu Apr 17 03:57:35 EDT 2008
Hi all.
As in one of my previous post on this list I experienced problem wrapping
the dateline for a Tilecache layer. In practice the column of tiles
eastwards to the 180 latitude was calling a not existent 004 folder into the
level 02 of the tilcecahc hierarchy. The level 02 has only 4 subfolders,
from 000 to 003.
I tried to understand where the error was generated but I didn't find it.
For now I changed the getURL function into the OpenLayers.Layer.TileCache
to:
getURL: function(bounds) {
var res = this.map.getResolution();
var bbox = this.maxExtent;
var size = this.tileSize;
var tileX = Math.round((bounds.left - bbox.left) / (res * size.w));
var tileY = Math.round((bounds.bottom - bbox.bottom) / (res *
size.h));
var tileZ = this.map.zoom;
* Zero-pad a positive integer.
* number - {Int}
* length - {Int}
* Returns:
* {String} A zero-padded string
function zeroPad(number, length) {
number = String(number);
var zeros = [];
for(var i=0; i<length; ++i) {
zeros.push('0');
return zeros.join('').substring(0, length - number.length) +
number;
var corrX = zeroPad((parseInt(tileX) % 1000), 3);
if(corrX== '004'){
corrX= '000'
var components = [
this.layername,
zeroPad(tileZ, 2),
zeroPad(parseInt(tileX / 1000000), 3),
zeroPad((parseInt(tileX / 1000) % 1000), 3),
corrX,
zeroPad(parseInt(tileY / 1000000), 3),
zeroPad((parseInt(tileY / 1000) % 1000), 3),
zeroPad((parseInt(tileY) % 1000), 3) + '.' + this.extension
var path = components.join('/');
var url = this.url;
if (url instanceof Array) {
url = this.selectUrl(path, url);
url = (url.charAt(url.length - 1) == '/') ? url : url + '/';
return url + path;
This solved my problem for now but I know that is not the best way to solve
the problems. Is there anybody with a better knowledge of OL than me that
experienced the same malfucntioning and managed to solve it in a better way?
Thanks
Simone
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080417/10dfa270/attachment.html
