[OpenLayers-Users] deCarta DDS?
geoman csabbey at gmail.com
Tue Apr 22 11:04:58 EDT 2008
I would like to use OpenLayers for a project that uses deCarta's DDS as the
map server - the point would be to be able to swap out the map server
without affecting the higher layers. I don't see an OpenLS layer in
OpenLayers. Even if there was one, I'm not sure how closely deCarta conforms
to the spec.
Does anyone know of existing code I could use?
I am also very open to advice about other possible approaches if this one
just doesn't make sense.
Thank you,
Craig
View this message in context: http://www.nabble.com/deCarta-DDS--tp16824705p16824705.html
