[OpenLayers-Users] multiple epsg coordinates display
Alessio Di Lorenzo alessio.dilorenzo at gmail.com
Thu Apr 24 04:53:43 EDT 2008
Hi list,
with the precious suggestions of Giovanni Allegri I solved this issue!
There where two problems:
1) there were typos (as Chris said) in my code: various "scr" instead
"src" linking the js scripts in the header... ahhaarg
2) it is mandatory to set Proj4js.libPath='proj4js/lib/'; in the init
function to access to projCode/utm.js, that is needed to interpret UTM EPSGs
Hope this will be helpful for someone in future,
alessio
Alessio Di Lorenzo ha scritto:
> Hello,
> by reading on the web I noticed that what I want to do is possible
> through proj4js library
> "Support for reprojecting user-facing controls like mouseposition"
> Cuold someone show me any examples?
>> Hi list,
>> I have a little OL application showing data in utm33-wgs84 (epsg:
>> 32633) and I'm using a separate div to display the mouse position in
>> 32633 with no problems.
>> What I'd like to do is to display the mouse position also in
>> geographical wgs84 (epsg: 4326) in another different div.
>> In this way users could see both 32633 and 4326 coordinates at the
>> same time.
>> Is it possible?
>> thx
